auto gear box problemknotty8 01-30-2005, 03:20 PM HI, i have a 1996 grand cherokee ltd 40.auto i am having a problem with the gear box when i set of on my jurny the gear box goes from first gear to second gear no problem,But when going into third gear the reves go up and it does not go into third until i rev the engine more then it goes in gear the rest of the gears are fine just that one And it does this all the time could it be the clutch ,PLEASE HELP JDPascal 01-30-2005, 03:43 PM Welcome to the forum knotty8. The problem is with the apply of the forward clutch in the auto transmission. The clutch piston seal deteriorates due to the finish on the clutch drum. I have the same problem with my 96 JGC 5.2.... I have done a partial ATF change to the chrysler ATF+4 and it has improved the 2-3 shift by about 50%. I will be doing an additional part fluid change to increase the proportion of the +4 in the transmission and see if the improvement continues. Regardless, I will be removing the transmission this spring/summer and replacing the seals, clutches and upgrading the regulating valve to allow lube flow to the transmission in park. It is my opinion that all chrysler transmissions would benefit from annual transmission fluid changes (even partial) and the use of the Chrysler spec 7176 +4 ATF fluid. :2cents: I don't know if the +4 is available in the UK or not. JD PS - No, I don't work for Chrysler or own shares in the company. :smile: McCann 01-31-2005, 03:45 PM Check out the thread "cold transmission" about 3 pages in from this one. It explains what I did when I had your problem..here is a link to it I think. Mike http://www.automotiveforums.com/vbulletin/showthread.php?t=319446 mx52nv 01-31-2005, 04:33 PM is the ATF+4 only through the dealer? JDPascal 01-31-2005, 05:36 PM Ya - you hafta go to the chrysler/jeep dealer for the ATF+4 -- BUMMER! JD Automotive Network, Inc., Copyright ©2012
