Factory fog lamp switch with non factory fog lamps.rlith 01-30-2005, 01:46 PM Well, I finally got tired of the original fog light switch I was using from Radio Shack. as it didn't fit with my interior really well. I finally decided to try and wire in a factory fog light switch to my truck that did not have the fog light harness installed as it does with the 98+ models even if it doesn't come with fog lights. Well I have to say it was a resounding sucess and I'm very pleased with it. I had to wire my upper fogs to only be able to be turned on with the lights and go off with highbeams due to the law. I do have an upgraded harness do to the fact that I have a hidden switch that turns on both sets of fogs, (top 55watt, bottom 100 watt), my low beams (silvania silverstars) and my highs (APC white 125 watts) at the same time to force those morons who refuse to turn off their highbeams after you flash them. I figure that a little bit of retina ghosting will teach them a lesson for the future! :bounce: But today we will be covering the simple 2 lamp fog light wiring. Parts Needed: Fog lamps (Your choice) GM Switch part # 15953150 4 or 5 wire sealed relay (you can also get specific fog lamp relays with wires attached) Here is my old switch...Simple radioshack toggle switch. http://home.comcast.net/~slavrinc/oldswitch.jpg Here is the Factory Switch. http://home.comcast.net/~slavrinc/switch2.jpg Here is the back of the new switch.. http://home.comcast.net/~slavrinc/switch1.jpg You will see that Pin 1 is opposite the key. Wiring is as follows. Pin-1---12v+ from headlamp Pin-2 & Pin-5 splice together to go to 85 on relay Pin-3 Brown on light switch (to light the switch itself with regular lights on) Pin-4 Ground. Relay- 85 from Pin 2/5 on switch 30 to Battery 86 to ground 87 to positve on fog lamp Foglamps. Splice 12v+ together to 87 on relay Grounds to frame or relay ground. (I prefer frame) Here is the finished pic.. http://home.comcast.net/~slavrinc/final.jpg http://www.pghconsulting.net/teal/images/Front-2_jpg.jpg Optionally you can replace the lights in the switch with your favorite color LED's. Requirements are as follows LED-3mm (no bigger) 2500 CMD (or better) with 150 ohm resistors to anodes. I've already ordered mine. The switch itself is cake to take apart. It's how I figured out the pins and that 5.mm are too big :cool: I hope this helps a few people. BlazerLT 01-30-2005, 03:12 PM excellent..Excellent EXCELLENT! I am currently going to be replacing my air dam with a Wingswest with fog lamps and now I can get them wired up. rlith 01-30-2005, 06:51 PM I should also mention that the switch runs about 23.00 at the dealer. BlazerLT 01-30-2005, 07:08 PM Wiring schematic? rlith 01-30-2005, 09:07 PM No drawings, but the wiring sequences are above BlazerLT 01-30-2005, 09:35 PM Can you post more on the relay setup, some people would like to upgrade to foglamps and this woul dbe a great guide on how to do it. blazee 01-30-2005, 09:51 PM I made a crude scematic of what he is talking about http://files.automotiveforums.com/gallery/watermark.php?file=/503/279217schematic-med.jpg blazee 01-30-2005, 11:33 PM rlith, Correct me if I'm wrong...I'm guessing that pin 2 is the output of the switch and pin 5 is an input for a "lights on" indicator led. That's why they are tied together. I wasn't sure so I didn't put it in the schematic. BlazerLT 01-30-2005, 11:45 PM I just would like to see where the connection are made to the relay. Is it a separate relay? s10blazerman4x4 01-13-2006, 10:27 PM Have you gotten the info to update the schematic? I ask in case it gets looked at in the FAQ section. dmbrisket 51 01-14-2006, 04:37 AM blazze, rlith, thank you so much, gettin ready to hook up the fog lights in the truck, now i dont need to use that ugly ass thing that you had lol snorander 10-05-2009, 01:00 PM OK I want to do this on my 2001 Jimmy. I got the new switch & my truck has the connector allready attached to the harnes. http://img246.imageshack.us/img246/3904/connector.th.jpg (http://img246.imageshack.us/img246/3904/connector.jpg) http://img169.imageshack.us/img169/4002/1005091218.th.jpg (http://img169.imageshack.us/img169/4002/1005091218.jpg) http://img180.imageshack.us/img180/5724/1005091219.th.jpg (http://img180.imageshack.us/img180/5724/1005091219.jpg) I am currently using a switch with 3 connectors(ground, lights, & power to the switch). How do I connect it? It doesn't matter to me if the lights turn off or stay on with the high beams. Any help would be greatly appreciated! thanks! Steve snorander 10-05-2009, 02:44 PM OK I want to do this on my 2001 Jimmy. I got the new switch & my truck has the connector allready attached to the harnes. http://img246.imageshack.us/img246/3904/connector.th.jpg (http://img246.imageshack.us/img246/3904/connector.jpg) http://img169.imageshack.us/img169/4002/1005091218.th.jpg (http://img169.imageshack.us/img169/4002/1005091218.jpg) http://img180.imageshack.us/img180/5724/1005091219.th.jpg (http://img180.imageshack.us/img180/5724/1005091219.jpg) I am currently using a switch with 3 connectors(ground, lights, & power to the switch). How do I connect it? It doesn't matter to me if the lights turn off or stay on with the high beams. Any help would be greatly appreciated! thanks! Steve I guess I would like the easiest way to hook it up, I have an orange, purple, brown, & black wire on the connector. I am guessing that orange should be power, brown is the dash lights, black is the ground, but I have no idea what purple is. So do I run power to the orange wire, splice the brown to another dash light wire, splice the balck wire to a ground and run the purple to my fog lights? -Steve snorander 10-12-2009, 02:58 PM OK I want to do this on my 2001 Jimmy. I got the new switch & my truck has the connector allready attached to the harnes. It has a gray wire (power from the head lights), A black wire(Ground), A purple wire (amber light that lights up when the light is on), & and an orange wire(which I assume is power out to the lights). I tried splicing my lights onto the orange wire, but that did not work. My truck allready has the relay (labled foglps) in the fuse block under the hood. Anyone know how I can make this switch work? With the headlights on I put my test light on the orange or the purple wire I get nothing. I tried holding the button down & testing, but again I get nothing. when I turn the headlights on I get power on the gray wire and the white on the front of the switch(dash lights) lights up, but other than that I get nothing. I'm stumped, any help would be greatly appreciated! Automotive Network, Inc., Copyright ©2012
