power windows
spita
03-14-2002, 02:05 PM
i gotz a 93.5 p10 with power windows. the passenger window switch on the center console will only put the passenger window down an not up. i wanna know if i can fix this myself an how, or if not what to do?
:smoker2: 1
Swonder67
03-14-2002, 05:08 PM
Sounds like the switch is broken. Just get a new switch and replace it.
A380Driver
03-16-2002, 05:55 PM
:smoker2: 1
If you're sure its the switch, get a used one from some place like www.autogator.com or whatever parts junkyard you like. You will need to take off the center console.
There is one screw by the drivers foot, and one screw by the pax foot. There are also one screw on each side of the console right where the back of the seat is on either side. There will also be 2/4 more screws holding it down in the center. To get to these you need to take off the molding piece around the shifter and the floor piece below the handbrake.
You will be able to pull it up a bit...this will be enough so that you can reach your hand underneath and unplug the wire harnesses that are plugged into the power window switches/lock...etc. There will be one on each side. Once you do this, you should be able to pull out the center console. You will see that there is a two switch assembly that is screwed in to either side.
This is what you will need to order. Good luck.
