transmission fluid
johnson110
01-29-2005, 07:42 AM
I had my fluid changed 2 weeks ago, do you think i can drop the pan and change fluid this week myself and REUSE the old gasket! also do you use any type of gasket sealer on gasket, i hope not! Thanks for replys
xj31
01-29-2005, 01:50 PM
it depends on the gasket.if its a cork gasket dont even try.if its the mopar one that is made of metal,plastic and rubber,then it is reusable.
johnson110
01-29-2005, 02:22 PM
Well i reused the gasket and changed the fluid and filter also found i broken pan bolt and i stripped bolt i put some stick epoxy on those! damn mechanic did this oh well time will tell!
