BCM (Body Control Unit)TAGMXL 01-28-2005, 02:33 PM Good afternno to all of you. Some body could tellme where is located the BCM in a Cirrus LX 95' ? Thanks in advance. slant6er 02-09-2005, 02:21 PM Left side cowl. Behind/under the dash. Open the driver's side door, pop the cover over the fuse block. The BCM is located at the rear of the junction block. You can't get to it easily. annguyen1981 02-17-2005, 11:26 PM If you remove the front dash cover, then the driver knee panel, you should be able to access the BCM easier... The radio bezel should just pry off. If I remember right, there are four screws under that bezel that keep the front dash cover attached. Then under the fuse cover, there is one screw. then you just pull on the front dash cover... The driver knee panel has two screws deep near the pedals, and I think there were three screws near the steering wheel. Automotive Network, Inc., Copyright ©2012
