Water Pump problem
I just bought a 1994 740 il. The radiator, water pump and the fan looked brand new. Not even a dust grain on them. Less than two weeks driving it, I developed a leak in the radiator. The leak is right under the upper hose entrance from a round plastic extrusion. Looks like it is a safety pop-out. Seemed the pressure behind the closed thermostat was forcing the plastic open further. Few days later, my water pump started making grinding noise. In less than one hour the pump shattered bearing and seals. Since all above parts looked brand new, can anybody advise if the problem may be related to other malfunctioning other than bad luck. The car was not in an accident. I checked with Carfax and all seem to be OK.
