car won't start help me pleaseafast 01-28-2005, 12:16 AM last week i was driving my car to work and it acted like it ran out of gas. it didn't i have a full tank. i then replaced the fuel pump and filter. the car still won't start. any advise , i'm desparate. ps it's not the starter and fuel is getting through to the filter but i don't know about the injecters, do they just clog with no warning? Jet-Lee 01-28-2005, 10:12 AM my car did this when my Camshaft Position Sensor went out. Luckily I knewwhat it was when it happened. It could be an option for you, but I'm not 100% sure. I don't know if there is a way to test it. Do you ahve a CEL? chevyn0va1 01-28-2005, 11:08 AM my car did this when my Camshaft Position Sensor went out. Luckily I knewwhat it was when it happened. It could be an option for you, but I'm not 100% sure. I don't know if there is a way to test it. Do you ahve a CEL? i know you can pull the electrial plug off each fuel injector and test to see if they are getting voltage. Jet-Lee 01-28-2005, 12:03 PM check them for resistance...I believe it's ~17ohm resistance per injector. check ur compression while ur at it. ~170psi per cylinder is about average, i think. As long as the least is no less than 10% below the highest. chevyn0va1 01-28-2005, 12:07 PM check them for resistance...I believe it's ~17ohm resistance per injector. check ur compression while ur at it. ~170psi per cylinder is about average, i think. As long as the least is no less than 10% below the highest. humm check the electrical plugs or the (other end) the injectors also? autoenthus3 02-04-2005, 10:52 AM Did your lights and radio shuf off? If they did then its an electrical problem... prob alternator or battery Davescort97 02-04-2005, 12:05 PM The Fuel pump switch located in the trunk and accessed by a removable panel could have tripped if you had a sudden jolt. Just press the button on the top to reset it. wikedjnj 02-14-2005, 07:16 PM Check The Timing Belt. Take The Cover Off, If It Is Still On, Mark It With A Marker, Turn The Engine Over And See If It Changed Position lilhotmama0302 02-18-2005, 12:55 PM The Fuel pump switch located in the trunk and accessed by a removable panel could have tripped if you had a sudden jolt. Just press the button on the top to reset it. I was in a car accident and only hit the passenger back corner, my 95 escort acts like it wants to start but studders a little then its back to the drawing board of trying again, seems like your quote may be the answer, i'll try that and get back to you, Thank u, this web page is so great for people to use when u are low on funds and need a little help! Automotive Network, Inc., Copyright ©2012
