ECU codes
Google
Web AF
barrlucas
06-25-2001, 11:03 AM
Can anyone with a factory sevice manual post a list of the ECU codes and what they mean, my check engine light came on and the stealership wants 80 bucks just to hook up a consult and check the codes. I got a list off of se-r.net for the 95-98 200sx ser but I am not sure if it is the same TIA.
zerogee321
06-30-2001, 08:55 PM
goto the se-r.net and search the archives, they have all the codes at your fingertips. i know i have used them more than once to save my butt.
aluke000
08-12-2001, 03:25 AM
Don't you hate it when people don't read your post all the way through before answering? I have a 95 G and I would also like to know if the codes on SE-R.net are the same for the G. I have a Haynes Primera manual but it doesn't have the ECU codes in it.
G20er
08-12-2001, 01:32 PM
I have a 92G20 FSM and here is the list for ECU codes:
11 Crank angle sensor circuit
12 Air flow meter circuit
13 Engine temp sensor circuit
14 Vehicle speed sensor circuit
21 Ignition signal circuit
31 ECU
32 EGR function
33 Exhaust gas sensor circuit
34 Detonation sensor circuit
35 Exhaust gas temperature sensor circuit
43 Throttle sensor circuit
45 Injector leak
55 No malfuction in the above circuit
I hope this helps
L8R
G20er
Google
Web AF
