94 auto ls swap to 98-01 manual type-rLowTegg 01-26-2005, 09:17 PM i have a 94 auto ls that i bought for 5000 bucks i pu ton a full i/h/e and i did alot of body work on it for 4500 and now it looks exactly like a type-r but does not run like one i want to swap in a 98-01 jdm engine with manual shift the motor comes with: Complete Motor - Block - Intake Manifold - Complete Head - Sensors - Exhaust Manifold - Fuel Rail - Injectors - Distributor - Throttle Body - Alternator - Starter - Ignition Wires - A/C Compressor - Power Steering Pump - Headers(JDM 4-1) • OBD2 ECU (Computer) • 5-Speed FWD Hydraulic LSD Transmission - With Clutch components assembled to the engine • Axels • Intermediate shaft • Engine Mounts • Wiring Harness and i know i need a shifter knob boot pedals and type-r guage cluster set-up theres other things i forgot my friend and i are going to do the swap ourselves he has experience with swaping integra engines we just need to know what all or else we need so we are set and ready for the swap?? thanks for the help and feedback civickiller 01-26-2005, 09:31 PM you need the pedal assembly, the hydro lines, the clutch master cylinder, clutch slave, shifting assembly Automotive Network, Inc., Copyright ©2012
