Originally Posted by wvance
what do you mean, cv joint went out. sure that would cause steering to pull to one side
Don't put words in my mouth. I didn't say it went out . you asked if a bad cv would cause this? It could if bad enough. start with the easy stuff first .
I had said try alingment, this will trouble shoot most of the things that will cause you car to stray. the tech should tell you what is the cause if he checks it out.
So I hope this is a little more clear to understand
