Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Nova
Old 01-26-2005, 04:46 PM   #1
sky73
sky73 Normal reputation
How much horsepower?
Hi. I was wondering if anyone would have an idea on how much horsepower this engine is making.
1973 GM 350
2 bolt main
bored 30 over
comp cams 256 xtreme energy cam
world sportsman II cast iron heads (72cc chambers)
edelbrock performer intake
edelbrock performer 600 cfm carb
K&N filter
Thank you.
sky73 is offline   Reply With Quote
Old 01-26-2005, 09:47 PM   #2
Fyter87
Fyter87's Avatar
Fyter87 Normal reputation
Re: How much horsepower?
Not really a true guess, but I would say probably little over 350, I could be totally of though.
Fyter87 is offline   Reply With Quote
Old 01-27-2005, 12:49 AM   #3
mik13usa
mik13usa's Avatar
mik13usa Normal reputation
What kind of fuel? compression ratio?
mik13usa is offline   Reply With Quote
Old 01-27-2005, 05:22 AM   #4
Robs71Nova
Robs71Nova's Avatar
Robs71Nova Normal reputation
Send a message via AIM to Robs71Nova Send a message via Yahoo to Robs71Nova
After looking at the specs on it, the cam is too small.
Lift: .447''/.454''
Duration: 256°/268°
RPM Range: 1000-5200
You have a good set of heads thay are gonna flow alot of air, and .30 overbore which actually makes the motor a 355, but the cam is just to small for the motor. You could also use a slightly bigger carb. As it is, Id say 325 horsepower, and 350ish torque, but that cam is really choking you up. With a better cam, and 650-750 cfm carb, I would put you in the 360-375 horsepower range with around 400 ftlbs of torque.
Rob
Robs71Nova is offline   Reply With Quote
Old 01-27-2005, 10:30 AM   #5
sky73
I run 91 octane pump gas
comp ratio is around 9.0:1
Old 01-27-2005, 03:01 PM   #6
mik13usa
mik13usa's Avatar
Rob is pretty close, I would guestimate about 300 horses, 350 lbs torque unless the cam gives it plenty of valve movement you are restricted, as well as the 600 CFM Edelbrock, believe it or not the Rochester (Q-Jet) flowed higher to about 730 CFM.
Old 02-15-2005, 05:49 PM   #7
sky73
Ok. Thanks.
Bookmarks
Google
Web AF
