Keyless entry 2000 VentureDave25 01-26-2005, 09:54 AM I would like to know how to program key fobs for my 2000 Chev Venture. ggcatt 01-26-2005, 02:39 PM First, be sure that the fobs you have are the correct part number for your vehicle. Then, go to the owners manual, and it should give you instructions. Dave25 01-27-2005, 06:11 AM First, be sure that the fobs you have are the correct part number for your vehicle. Then, go to the owners manual, and it should give you instructions. I have tried that but it doesn't do the trick. I have purchased another key fob with the identical numbers as my original ones and need to code it to match my originals. spider22 01-27-2005, 02:55 PM Here are the instructions that I found on this site. They worked for me, other than i did not always get the chimes that it claims you will. Remove the ignition key from the ignition lock cylinder. Remove the BCM PRGRM fuse from the fuse block. Refer to Electrical Center Identification Views in Wiring Systems. Close all of the doors. Insert the ignition key into the ignition lock cylinder. Turn the ignition to ACC. The body control module (BCM) will perform the following in order to identify the type of BCM installed in the vehicle: Flash the seat belt indicator 2, 3, or 4 times. Chime 2, 3, or 4 times. Turn the ignition to OFF, and then back to ACC within 1 second. The BCM may begin to chime and flash diagnostic trouble codes (DTCs). If the BCM has stored any DTCs, refer to Diagnostic System Check - Body Control System in Body Control System. Open and then close any vehicle door. The BCM will chime in order to confirm that the programming mode has been entered. Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for approximately 14 seconds. Important After approximately 3-5 seconds the BCM will chime once to confirm that the programming has been completed for that transmitter. Repeat the previous step in order to program each additional transmitter. Remove the ignition key from the ignition lock cylinder. Install the BCM PRGRM fuse into the fuse block. Operate the functions of each transmitter in order to verify correct system operation. Hope this helps, Jed Dave25 01-27-2005, 07:47 PM Here are the instructions that I found on this site. They worked for me, other than i did not always get the chimes that it claims you will. Remove the ignition key from the ignition lock cylinder. Remove the BCM PRGRM fuse from the fuse block. Refer to Electrical Center Identification Views in Wiring Systems. Close all of the doors. Insert the ignition key into the ignition lock cylinder. Turn the ignition to ACC. The body control module (BCM) will perform the following in order to identify the type of BCM installed in the vehicle: Flash the seat belt indicator 2, 3, or 4 times. Chime 2, 3, or 4 times. Turn the ignition to OFF, and then back to ACC within 1 second. The BCM may begin to chime and flash diagnostic trouble codes (DTCs). If the BCM has stored any DTCs, refer to Diagnostic System Check - Body Control System in Body Control System. Open and then close any vehicle door. The BCM will chime in order to confirm that the programming mode has been entered. Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for approximately 14 seconds. Important After approximately 3-5 seconds the BCM will chime once to confirm that the programming has been completed for that transmitter. Repeat the previous step in order to program each additional transmitter. Remove the ignition key from the ignition lock cylinder. Install the BCM PRGRM fuse into the fuse block. Operate the functions of each transmitter in order to verify correct system operation. Hope this helps, Jed Thanks for the help, I'll do it tomorrow. Automotive Network, Inc., Copyright ©2012
