I have a 1995 suburban, I was in a wreck in oct. it was hit on the front left. but anyways, after it was fixed I was having problems with the left blinker blinking faster then it should, now it is fine but I am having problems with the transmission. I just had the shifting silinoids replaced and that didn't help. sometimes it is fine but most of the time it isn't. When I start out from a stop it doesn't seem to want to go and the engine revs up then it will start going. If I put it in first or second gear and shift up to third and drive it is fine but doesn't seem to come out of overdrive. Plus my tacometer and speedometer doesn't work most of the time, and the shift selector light goes out. Plus I get the check gages light and when driving it flashes but when idling it just stays on unless it is in first or second gear. I hope this is clear enough.
Thanks
Renee
