Re: 94 Golf III stopping when hot
I have the same car with the same problems but i fixed DO YOU WANNA know how....
*******fuel pump******* yes beliv or not
that F***** fuel pump give me the problem of my life i will stay on trffic for long time and my car will stall turn off, will start right back on this problem stay for a while until a GOOD MEXICAN mechanic from VW dealer toll me i bought the fuel pump in the company i work for cost me 180.00 (this pump is inside the tank you need to access from the trunck right hand side, )
note:if you are going to buy that pump tell your mechanic to check the fuel pressure,,,also to get to fuel pump you have to remove a big plastic nut you going to have to beat the s*** out of that thing so might bracket so before doing that i recomend to but the nut and the seal along with the fuel pump part number are:
1: 1hm 919 051m fuel pump
2: 1h0 919 133 seal for pump
3: 321 201 375 A union nut this is the one believe me you will bracke...... mine was so hard that i had to cut it...
Problem fix
