Ford Escort 93 Hatchback Occasional Erratic Idle / PCV Valve Locationcheesyhoward 01-24-2005, 04:43 PM I have a Ford Escort Zetec 1.6 93/L car (100000 miles). Sometimes the car does not idle very well when cold. There is a lot of vibration and some throttle is required to prevent the engine stalling. This lasts for a couple of minutes and then everything is fine. This normally occurs after I have started the engine a couple of times to move it in and out of the driveway on the previous day. I have recently changed the air filter and pcv filter. I am planning on cleaning / replacing the vacuum hoses and PCV valve. I am having difficulty locating the PCV valve. Whereabouts is it and is it easy to change? Is it what the blue arrow is pointing to in the pictures below? http://www.hkbooks.freeserve.co.uk/car/pcvoverview.jpg http://www.hkbooks.freeserve.co.uk/car/pcvcloseup.jpg Is the clip in the picture shown below of the cylinder head cover breather pipe to the air filter box reusable or does it have to be replaced? http://www.hkbooks.freeserve.co.uk/car/overview.jpg http://www.hkbooks.freeserve.co.uk/car/closeup.jpg http://www.hkbooks.freeserve.co.uk/car/closeup2.jpg Another unrelated question I need to take off one of the rear door trims to treat some rust. Are they stuck on or are there plastic clips / something else holding them on? Are there any good methods for removing it? I was thinking of using a piece of fishing line to break the seals. http://www.hkbooks.freeserve.co.uk/car/trim.jpg Jet-Lee 01-24-2005, 04:52 PM If the trim is just stickied to the doors, use a hairdryer. For your lack of power, change ur plugs and wires then go from there. EGR valve, I didn't think Zetec's had one, but I don't know the Zetec engines either, I'm an SPI guy so I can't help ya there, sorry. Automotive Network, Inc., Copyright ©2012
