engine surge
tomek_69
01-24-2005, 08:30 AM
when i drive this 1g at low rpm 1,2,3,4,5 gear i get a surge its like the engine cuts of verry briefly but only when i let of the gas mainly at coasting to accelerating kind of like the timing is not adgusting ive tryed turning the cam sensor 180 and it dosent change
91 rs 5 spd hacked mas can
macder
01-24-2005, 08:51 AM
Check your plugs, this is most likely your problem if it's cutting out at low rpm.
BTW, a surge is when your RPM's raise without touching throttle.
How where you able to turn the cam sensor 180?
Since you've been playing w/ your cam sensor you might have advanced the ignition timing to far and are getting lots of rod knock, hense your motor cutting out. Try putting higher octane fuel in, my cam sensor is advanced 5 degrees and have no choice but to use 91+ octane gas to avoid knock.
tomek_69
01-24-2005, 08:53 AM
new plugs
gen2gst95
01-24-2005, 03:02 PM
if you put in new plugs, replace the plug wires too, and maybe a new distributer cap also.
