Evos and a GSXLegionofone 01-23-2005, 04:07 PM ok whats the differnece in a evo and a GSX i know its got like 60+ more HP... but the same engine the only thing different is the compression ratio and the RPMs were the car makes the most torque and HP Compression: Eclipse 8.5:1 Evo 8.8:1 Horsepower: Eclipse 210 @ 6000 RPM Evo 271 @ 6500 RPM Torque (lb-ft): Eclipse 214 @ 3000 RPM Evo 273 @ 3500 RPM viet_boiiiii 01-23-2005, 04:28 PM The engine of the evo has the cams facing the passanger side. Eclipse body= smooth and sleek. Evo body= boxed and riced out. haha thats all i know. scottsee 01-23-2005, 04:28 PM tdo5h 16g Legionofone 01-23-2005, 04:30 PM scott ur saying its got a different turbo? viet_boiiiii 01-23-2005, 04:30 PM It has a 16g turbo which is bigger. WildJokers 01-23-2005, 04:35 PM The Evo uses the same basic design as our 2g 7bolt. As someone else posted they have the 16g Turbo, and they also run at a higher lbs of boost then our cars do. kjewer1 01-23-2005, 04:37 PM Any DSM can be made to make the same power as the EVO. Fundamentally the motors are the same. joemathews 01-23-2005, 04:40 PM Cams are reversed (intake cam and exhaust cam are swapped when compared to our cars), but that doesn't account for the power difference. Like Scottsee said, Evo8s have a 16g turbo. Put an EvoIII 16g on your car and tune it well, and you will be putting out horsepower comparable to or above what the Evo8 produces. 1stGenRocks 01-23-2005, 04:53 PM Cams are reversed (intake cam and exhaust cam are swapped when compared to our cars), but that doesn't account for the power difference. Like Scottsee said, Evo8s have a 16g turbo. Put an EvoIII 16g on your car and tune it well, and you will be putting out horsepower comparable to or above what the Evo8 produces. i'd just add to this that you also need the proper supporting mods for a 16g. Legionofone 01-23-2005, 05:34 PM cool... now my bigger question... could u fabricate a 2g body over a evo 8 with little problem? or are the frames REALY different kjewer1 01-23-2005, 05:41 PM Evo is based on the lancer platform. Quite different. I don't know why you have a boner for the EVO8, put the same parts on the 2g and you have the same power. No need to reinvent the wheel. As far as I know the fastest EVO is in the 9s, and the fastest awd DSM is in the 8s. They both have the same potential, since they have the same motor. Legionofone 01-23-2005, 05:57 PM i have a boner for GSXs i would just like a BRAND NEW 2g :) eventualy... i was thinking get a evo powertrain and frame and fabricate the 2g body over it... i know it would cost alot but would be cool to have a nearly brand new GSX... GotGrip666 01-23-2005, 05:58 PM The engine of the evo has the cams facing the passanger side. Eclipse body= smooth and sleek. Evo body= boxed and riced out. haha thats all i know. explain on how the evo is riced out 97_3clipse 01-23-2005, 08:41 PM i have a boner for GSXs i would just like a BRAND NEW 2g :) eventualy... i was thinking get a evo powertrain and frame and fabricate the 2g body over it... i know it would cost alot but would be cool to have a nearly brand new GSX... or you could just replace all the parts.....honestly it really wouldnt make much sense, i dont even think the wheel base is the same.... Livid 01-23-2005, 10:02 PM Actually i believe there are 5 different models of the EVO8 .. 400hp, 340hp, 320hp, 300hp, and 260hp model. With the turbos being of different sizes. imtheoneandonlyD 01-23-2005, 10:05 PM Yeah i dont see how the evo is riced out. I like the way it looks. JoeWagon 01-23-2005, 10:17 PM Actually i believe there are 5 different models of the EVO8 .. 400hp, 340hp, 320hp, 300hp, and 260hp model. With the turbos being of different sizes. I have never heard of this. I only think there are two versions of the EVO 8, the production models with the japanese restricted ~280hp in both JDM and american versions, and the WRC car if you consider that, which has who knows how much power. gsxeclipse97 01-23-2005, 10:18 PM Actually i believe there are 5 different models of the EVO8 .. 400hp, 340hp, 320hp, 300hp, and 260hp model. With the turbos being of different sizes. in what country are we talking about. I know in the uk they have the fq300 that has 300hp and the evo 9 is suposed to have 300 to 350 stock but as far s 400 goes i don't believe so... clipsekid99 01-23-2005, 10:20 PM what about the Evo MR? JoeWagon 01-23-2005, 10:22 PM what about the Evo MR? what about it? you should provide more of a question, i have no idea what you are asking. The model of EVO in america doesn't change the engine, it's just options. gsxeclipse97 01-23-2005, 10:26 PM the mr is has lower center of gravity and 6 speed gear box and a little more tq than the evo and weighs less but it is still rated the same hp Livid 01-23-2005, 10:26 PM actually if u watch this... http://web.ics.purdue.edu/~fsiddiqi//CSi/FQ400-Topgear.wmv it will show u all the models and compare them.. It evens shows the evo taking a murielago on the corners and keeping up in the straights. clipsekid99 01-23-2005, 10:27 PM what about it? you should provide more of a question, i have no idea what you are asking. The model of EVO in america doesn't change the engine, it's just options. I was just stating that model from what Livid had said about there being many models Livid 01-23-2005, 10:31 PM ya sorry didnt mean model just meant engine viet_boiiiii 01-23-2005, 10:45 PM explain on how the evo is riced out Well thats my opinion.. sorry if i offened any1. The car looks good and all but ever since the evo and 2 fast 2 fur came out i see tons of civic with the same wing and a fake front mount intercooler. I ment to say, Evos make other peoples car turn into ricer machines. joemathews 01-23-2005, 11:38 PM That video posted above is impressive--saw it on Tuners. In any case, I completely dislike the appearance of the Lancer in every way. I think it looks like a boxy RC car. It just doesn't look sleek or intimidating in any way, IMO. That said, its performance is fairly astonishing. But I'll take a 400 hp 99 GSX over an Evo8 any day of the week. Shpyder 01-23-2005, 11:51 PM the lancer evo looks good from the front, but side and rear views are terrible. the rear wheel well and fender is structured and placed in such a way that even 18" wheels end up looking small and out of place. The rear looks small and toy-like, plus that huge rear wing on a 4-dr car doesnt look good at all. it performs like a winner, but IMO they need to clean up some of the designing. I wish they brought back the 4g63 in the new eclipses. that would be a blast. Legionofone 01-24-2005, 12:08 AM haha the 400 SUCKZ metalhedskater 01-24-2005, 12:54 AM Yea i dont know i sometimes like the lancer looks and sometimes dont....Its like it has bad days and good days like some kind of super model or something. Anyway, yea i really do think they need to redisign...first thing they should do is convert it into a 2 door, and make it a little less tall looking and fat looking and fix the doors....just imagine... it would look real nice. kjewer1 01-24-2005, 12:56 AM I think I just stepped onto another planet... Where am I? george536 01-24-2005, 02:41 AM Do you guys think the 4g63 will ever come back into the eclipse? im seriously gonna probably end up owning an Evo, just because i see it as a newer GSX. But hopefully they will put the 4g63 into the eclipse, hey maybe they put some sort electric/4g63 mixture thing into it? LOL Ill probably be 50 by then. lol 97_3clipse 01-24-2005, 04:37 PM Do you guys think the 4g63 will ever come back into the eclipse? im seriously gonna probably end up owning an Evo, just because i see it as a newer GSX. But hopefully they will put the 4g63 into the eclipse, hey maybe they put some sort electric/4g63 mixture thing into it? LOL Ill probably be 50 by then. lol i dont see the 4g63 making a return in the near future (2005-2008) ....the older 4g63 will never be back. but mitsubishi has the evo as the AWD turbo car. i dont see any reason why it would be smart for them to have 2 platforms of the AWD turbo ,from the bisness end of the spectrum... metalhedskater 01-24-2005, 04:57 PM yea the evo looks really bad and boxy because of its number one competitor....the STI...thats the only reason they keep thje turbo charged to the 4 door, which i think is pretty stupid... Turbo Meg 01-24-2005, 05:39 PM the mr is has lower center of gravity and 6 speed gear box and a little more tq than the evo and weighs less but it is still rated the same hp Correct on the lower center of gravity and six speed. All US. cars come with the same power, however the lightest version would be the RS. The RS comes power delete No ABS, no power locks, windows or radio. The RS also has no insulation or trunk carpet and no rear wing . They do in the US come with A/C and the sport meter kit, but only come in white or red. The RS is 200+ LBS lighter then the MR. GotGrip666 01-24-2005, 05:47 PM the 4g63 will most likely never be back in the eclipse do to the mitsubishi's concer of the up keep you need when the were running them, to many problems, to many concervatives complaing soyee7 01-24-2005, 11:38 PM the evo is a 4 door because it has been like that since its birth they cant just redesign it like they did the eclipse, otherwise it would piss off the whole evo community. I think it looks great(for a RALLEY car), you have to consider that ralley is its roots and its designed for that purpose, its not suppose to be as good looking as our cars. But i think i would rather choose a 400 Hp evo over a 400HP gsx anyday. There first prototype transmissions were so advanced that the factory ecu's couldnt keep up with them so they had to tone down the trannys capabilities. But all said i would still never trade my Eclipse for one. Automotive Network, Inc., Copyright ©2012
