Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Corolla/Matrix/Voltz
Old 01-21-2005, 11:35 AM   #1
citykitty68
citykitty68 Normal reputation
98 Toyota corolla- Knocking Sound
Whenever I accelerate there is a knocking sound that comes right under the gas pedal. Not sure if thats the axle or what. If anyone has any ideas in what I should be looking for I would appreciate it.
citykitty68 is offline   Reply With Quote
Old 01-27-2005, 06:34 PM   #2
zulman
zulman Normal reputation
Re: 98 Toyota corolla- Knocking Sound
Check your engine mounts.When you acelerate the motor tries to rotate.If the mounts are bad or broken the engine rotates mor than required and so may be the exhaust hits the under side of the car.All the best!!
zulman is offline   Reply With Quote
Old 06-02-2005, 05:57 PM   #3
gb643dp
gb643dp Normal reputation
kitty, did you figure out the problem cause it sounds like the same thing happening to my corolla. At first I thought it was an exhaust leak but no luck there. It sounds really bad on hard left turns. Thanks.
gb643dp is offline   Reply With Quote
Old 06-04-2005, 06:41 PM   #4
kuj
kuj Normal reputation
Check you CV joint boot to see if it is torn open or cracked. If it is, then the CV joint needs to be replaced. Check both sides. If it makes noise when turning left, then the right side is bad.
kuj is offline   Reply With Quote
Old 07-01-2005, 03:49 PM   #5
citykitty68
I finally broke down and took to a shop. I had to replace my left front wheel hub. Hope this helps point you in the right direction.
Bookmarks
Google
Web AF
