Rotor REmoval
Google
Web AF
matador009
01-19-2005, 09:02 PM
I have a '99 Nissan Sentra GXE. I'm trying to do a brake job, I say trying because I cannot remove the front rotors. I have the caliper off and the new pads in but I cannot seem to get the rotor off. Any help would be greatly appreciated.
Stay Tuned
01-19-2005, 10:14 PM
theres two bolts behind the rotor that hold the caliper bracket to the hub. in other words if u already took off the caliper there should only be 2 other bolts back there. once u take those out u should be able to remove the caliper bracket. then the rotor should be able to come off, if not just give it a slight tap with a hammer to loosen it up.
matador009
01-19-2005, 10:27 PM
I removed those bolts as well. The rotor will not budge. Is it just rusted onto the hub and all it needs is a good nudge? I've tried using a hammer and a 2x4 to get it off but I won't give. I really hate to keep knocking on it if there's something else hold on to it. TNX
Stay Tuned
01-20-2005, 12:02 AM
ive taken off many rotors, only those 4 bolts back there, holon u took off the axle bolt???
matador009
01-20-2005, 08:17 AM
I did remove the axle bolt since I was told it needed to come off. I quickly realized it does not interfere with the rotor so I put it back.
I just wanted to be certain that rust is the only thing holding the rotor in place before I start hammerin' away.
Google
Web AF
