89 Probe Cd player trouble!!! HELP!!!Kyo-Hino 01-19-2005, 08:25 PM I have a 89 Probe GL and i need some help. I have a Cd player and i cant get it to work. I dont know what wire to hook it up to. Im trying to get it to go throught the Fuse box and i dont know which wire to use. Someone please help. Kanibal 01-20-2005, 01:39 AM wow a cd player from 89. that takes me back. id try the car audio section of the forum. Kyo-Hino 01-20-2005, 05:34 PM No, it’s a new cd player. I was trying to put it in the 89. Thanks. 96probegt 01-21-2005, 05:22 PM get a 12volt light tester and check all your wires with key off the one lights up is ur memory wire and then turn the key on and check all the wires again the next wire to light up is your ur acesory wire good luck lonelywolf8588 02-09-2005, 11:14 AM You have to ground the player yourself. Ford thought that it was genius to run the ground through the screws of the factory deck. You have to put a loop on the cd players ground wire and screw it into something metal that is connected to the chassis. Automotive Network, Inc., Copyright ©2012
