stering damper
Google
Web AF
lions83
01-19-2005, 06:30 PM
is this a hard job and will the wheels have top be aligned?
mx52nv
01-19-2005, 06:33 PM
very easy and no.
glass
01-19-2005, 07:15 PM
I changed mine on a 94 gc limited , wasnt that easy , I had to soak the tie rod attach tapered bolt with penetraiting oil overnight , raise the front of the car to take pressure off it, and use a "pully puller type tool to break the tight lock the tapered fit bolt made , it came loose with a "snap", was easy after that... some have a top nut to remove the strut, mine didnt , so that explains the above procedure
mx52nv
01-19-2005, 07:17 PM
it's about as hard as changing a tire. if you can't do that, you shouldn't be driving a Jeep....
glass
01-19-2005, 08:49 PM
we here use this site to help others , not attack them with verbage
Google
Web AF
