JDM red DEt valve coverericdd 03-11-2002, 07:59 PM I ordered a red det valve cover that I'm gonna swap and I was wondering If when I take off the valve cover do I need to change the gasket. anybody that has done cams should know 2002G20Racer 03-12-2002, 12:30 AM Where did you get it and how much did it cost??? ty423 03-12-2002, 01:15 AM Well it is recommended...what you can do is swap it and see if it leaks. Check it daily for a week and then monthly...If no leaks then it should be fine...Mine has been taken off and put on couple times and no leaks. The valvecover gasket is pretty thick and solid...it should be fine unless you have lots of miles which I would also recommend buying a new one. AznVirus 03-12-2002, 02:24 AM i say you change it cause the last own probably starved the engine of oil (just assuming, since ive heard of it a lot). a lot of parts on the engine require to replace the gasket everytime you take it off. 95flG20 03-12-2002, 02:02 PM i would change it. one of my buddys has the DET in his 240 with the red valve cover, looks VERY good. very nice! 240ztt 03-14-2002, 08:35 AM Originally posted by ericdd I ordered a red det valve cover that I'm gonna swap and I was wondering If when I take off the valve cover do I need to change the gasket. anybody that has done cams should know I did. It wasn't much for a new valve cover gasket. Also make sure that your DET valve cover has the round spark plug O rings inside the valve cover. If not just swap them out of your old valve cover. BTW I still have my stock valve cover if anybody wants it :) Blue94G20T 03-15-2002, 02:07 AM Originally posted by 240ztt BTW I still have my stock valve cover if anybody wants it :) How much? chefsg20 03-15-2002, 01:17 PM where do you get a red valve cover and whats a good price? Automotive Network, Inc., Copyright ©2012
