1997 Blazer Flasher?broken record 01-17-2005, 09:35 PM The turn signals and hazard lights suddenly went out on my 97 Blazer. I changed the fuse and still no luck. I've read some posts where either the turn signals or the hazards go out and the advice is usually to change the appropriate flasher, but if both go out at the same time is it more likely to be a bulb? BlazerLT 01-18-2005, 01:20 AM Change the flashers. Bulbs don't render your signal system dead. broken record 01-18-2005, 08:14 AM Will do. Thank you very much! BlazerLT 01-18-2005, 12:39 PM No problem. also, might want to swap in a new fuse just to be sure. broken record 01-18-2005, 12:48 PM Will do. I bought a new pack of fuses last week. Thanks again! imcrsmith 01-10-2006, 08:55 PM I give up, short of pulling out the dash board, I cannot locate the flasher unit on our 97 Blazer. Appreciate any help. DINO55 01-10-2006, 10:29 PM Did you look BEHIND the Glove Box? biv343 01-11-2006, 08:38 AM dino is correct - behind the glovebox. When I had this similar problem, it ended up being the multifunction switch that died. I had a constant 'clicking' sound from the flasher, until the smoke came out from behind the steering wheel anyways. Brian_D 01-11-2006, 09:43 AM On my '97 LT, the two flashers (one for turn signals, one for hazards) were located behind the dash, and if memory serves, just to the left of the "convenience center" (the dual cigarette lighter ports). Only the lower part of the dash needed to be removed. I had replaced my turn signal flasher with a higher amp flasher for towing. roadieken 01-11-2006, 03:31 PM On my '97 LT, the two flashers (one for turn signals, one for hazards) were located behind the dash, and if memory serves, just to the left of the "convenience center" (the dual cigarette lighter ports). Only the lower part of the dash needed to be removed. I had replaced my turn signal flasher with a higher amp flasher for towing. Yup...right there. Just replaced mine today. $3.00 at napa. Automotive Network, Inc., Copyright ©2012
