wheel bearing sensor diagnostic?
pp270
01-17-2005, 12:10 PM
Does anyone know how to tell if a wheel bearing sensor is bad aside from checking the codes?
JTrujillo86
01-17-2005, 12:17 PM
What does it matter which sensor is bad if you need to replace the entire hub assembly anyway?
Jeremy
pp270
01-17-2005, 12:54 PM
The problem is I receive a scan code that indicates a wheel bearing sensor is bad, but it doesn't indicate which of the four is bad. Also none of the bearings are making any noise so I am assuming one of the sensors is bad. This is why I would like to know how to diagnose an individual sensor.
Ridenour
01-17-2005, 08:37 PM
IMO, after replacing all four of mine, if you can't hear the wheel bearing humming / rumbling = it ain't bad. Honestly, if it's the least bit bad, you'll be able to here a resonating humming when you get up to certain speeds. If you've got the lights on, but can't hear it, I'd say it's probably just a fault sensor. I'm not sure how you would "diagnose an individual sensor" though. Maybe just replace all four sensors?
JTrujillo86
01-17-2005, 10:58 PM
You cannot replace any of the sensors in the wheel bearing...you need to replace the entire hub assembly because the sensors are encased within the hub.
Jeremy
Ridenour
01-20-2005, 08:02 PM
well yeh in my post I meant I replaced all 4 hubs, not all 4 sensors. So if you have a bad sensor, like Jtrujillo said, and your that annoyed by the lights, then replace the hub assembly and it should fix it. But for the money, I don't think it's worth it, unless you have an actual bad bearing = you can hear it.
