I am in the middle of changing the timing belt on my KIA Sportage and since this is the first time I have done open hart surgery on a car I have some questions before I close her up. The following are STEPS 5 – 9 of the instructions that I have for installing the timing belt on my Sportage.
- Install new belt but leave tensioner free.
- Turn engine in direction of rotation twice to insure everything remains lined up.
- Loosen tensioner lock bolt so tensioner goes against the belt
- Turn engine so the 'S' mark on the exhaust cam aligns with the mark on the top of the head and then tighten the tensioner lock bolt.
- It's done, except to put everything back together.
In step six, when I tried to turn the engine (by hand) I could not keep all the gears lined up, the belt is loose-fitting and gears move out of place, so I have undone the tensioner lock bolt at this time (before step 6) allowing the tensioner to hold the belt in place on the sprockets, and then I rotated the engine twice by hand, Is this OK?
If so then what is the reason for step eight? Am I screwing anything up by undoing the tensioner lock bolt so tensioner goes against the belt before step 8?
Once again thank you all for the Help!!!
