#1 Speed Sensor 2000 Celica GTEltokim735 01-17-2005, 08:12 AM Can anyone tell me how to change out the speed sensor. What do you need to remove on the engine inorder to gain access to the speed sensor. How is the speed sensor mounted to the transmission, does it simply screw out or is it secured with screws.What precautions should i take when changing out the speed sensor? Any help would be appreciated. Thanks... Gene Vip09 01-17-2005, 03:13 PM Can anyone tell me how to change out the speed sensor. What do you need to remove on the engine inorder to gain access to the speed sensor. How is the speed sensor mounted to the transmission, does it simply screw out or is it secured with screws.What precautions should i take when changing out the speed sensor? Any help would be appreciated. Thanks... Gene I think you would get more help over at newcelica.org. 91 Celica St 01-19-2005, 12:39 PM its mounted right on the top of the transmission...its simple it screws in ..not hard at alll Automotive Network, Inc., Copyright ©2012
