2001 Yukon keyless entry questionJHop 01-16-2005, 11:55 PM I have a 2001 Yukon, bought it used and did not get a remote for the keyless entry. Does anyone know the correct part number for the remote? Or info on what I need to do. I would rather not go to the dealer and spend a few hundred $$ Any insight would be greatly appreciated. 2000CAYukon 01-17-2005, 01:31 PM I just replaced one on my 2000 Yukon. Part # is 15732803. //2000CAYukon transgta 01-17-2005, 04:55 PM keylessride.com has your remote 4 59 bucks Eggert 01-18-2005, 12:15 AM HI, I think mine was $60 at the dealer. Programming instructions below: Body and Accessories - Keyless Entry - Page 8-875 Transmitter Synchronization • Resynchronization may be necessary due to the security method used by the remote keyless entry system. The transmitter does not send the same signal twice to the remote control door lock receiver (RCDLR). • The RCDLR will not respond to a signal that has been sent previously. This prevents anyone from recording and playing back the signal from the transmitter. • The panic button should still operate normally when the system is out of synchronization. • Resynchronization may be necessary under the following conditions: - The battery in the transmitter is very weak. - The battery in the transmitter was replaced. - The battery in the vehicle has been in a low or no charge condition for an extended period of time. • In order to resynchronize the transmitter with the RCDLR, perform the following steps: 1. Stand within 1.5 meters (5 ft) from the vehicle. 2. Simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for 7 seconds. The door locks should cycle in order to confirm resynchronization. Transmitter Programming Important: All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to four transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. You may program up to 4 transmitters, using either of the two following procedures: Transmitter Programming Procedure (Method 1 - No Tools Required) 1. Close all the vehicle doors. 2. Insert the ignition key into the ignition lock cylinder. 3. Press and hold the door unlock switch. 4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF. 5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode. 6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter. 7. Repeat the previous step to program up to four transmitters. 8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode. 9. Operate the transmitter functions in order to verify correct system operation. Transmitter Programming Procedure (Method 2 - Scan Tool Required) 1. Install a scan tool. 2. Turn the ignition ON, with the engine OFF. 3. Use the scan tool in order to access the Body Control Module (BCM) Special Function: Program Key Fobs menu. 4. Follow the directions on the scan tool in order to program the transmitters. 5. Operate the transmitter functions in order to verify correct system operation. Take care, Eggert :bananasmi mitchss 01-18-2005, 11:46 PM You might want to check on Ebay first. I picked up two remotes together for my 2001 Yukon for $18. They were in like new condition and worked perfect. I think I searched through all of the 2001 GMC Yukon stuff to find them. Automotive Network, Inc., Copyright ©2012
