2004 silverado headlinersugar bear 01-16-2005, 07:58 PM Does anyone know how remove headliner inorder to install xm antenna. (factory type that requires drilling roof) Rbo 02-16-2005, 12:14 PM Does anyone know how remove headliner inorder to install xm antenna. (factory type that requires drilling roof) Did it once before with a cell phone antenna, I'm sure it's very similar. If you pull off the A-pillars and possibly the B-pillars, visors and pull down the weather stripping you should be able to get enough clearance as long as you have a buddy hold down the headliner w/o creasing it you can drill from the top down. Make sure you use a short bit and extra care as to not go down to far and pierce the liner. Good luck Automotive Network, Inc., Copyright ©2012
