91 deville diagnostic codeswillh84 01-12-2005, 09:10 PM i recently bought this car and it came with no manual so if anyone could please tell me what these codes mean it would be greatly appreciated: E, E34, E91, E98, EE, E91, 7.0 MarkC 01-13-2005, 04:48 PM These codes were posted by someone earlier... these are good for 85-93 4.1 ,4.5, and 4.9 engines. > > Engine Control Module Codes > E12 - No Distributor Signal > E13 - Oxygen Sensor Not Ready > E14 - Shorted Coolant Temp. Sensor > E15 - Open Coolant Temp. Sensor > E16 - Generator Voltage Out Of Range > E17 - Shorted Crank Signal Circuit > E18 - Open Crank Signal Circut > E19 - Shorted Fuel Pump Feedback Signal > E20 - Open Fuel Pump Circut Feedback Signal > E21 - Shorted TPS Signal > E22 - Open TPS Signal > E23 - EST Signal Problem > E24 - VSS Signal Problem > E25 - EST Circut Problem in Bypass Mode > E26 - Shorted Throttle Switch Signal > E27 - Open Throttle Switch Signal > E28 - Open Third Or Fourth Gear Circut > E29 - Shorted Fourth Gear Circut > E30 - ISC RPM Out Of Range > E31 - Shorted MAP Sensor Signal > E32 - Open MAP Sensor Signal > E33 - MAP/BARO Sensor Correlation > E34 - MAP Sensor Signal Out Of Range > E35 - Shorted BARO Sensor Circut > E36 - Open BARO Sensor Circut > E37 - Shorted MAT Sensor Signal > E38 - Open MAT Sensor Signal > E39 - VCC Engagement Problem > E40 - Open Power Steering Pressure Switch Signal > E41 - Cam Sensor Signal Problem > E42 - EST Circut Open > E43 - ESC Circut Problem > E44 - Oxygen Sensor Signal Lean > E45 - Oxygen Sensor Signal Rich > E47 - BCM-PCM Data Problem > E48 - EGR System Problem > E49 - A.I.R. Control Problem > E51 - ECM PROM Error > E52 - PCM Memory Reset (See Note) > E53 - Distributor Signal Interrupt > E55 - Closed Throttle Angle Out Of Range > E58 - PASS-Key Control Problem > E59 - VCC Temperature Sensor Circut Problem > E60 - Cruise- Transaxle Not In Drive > E61 - Cruise Vent Solenoid Problem > E62 - Cruise Vacuum Solenoid Problem > E63 - Cruise Set vs. Vehicle Speed Too High > E64 - Cruise- Vehicle Acceleration Too High > E65 - Cruise Servo Position Sensor Signal Problem > E66 - Cruise- Engine RPM Too High > E67 - Cruise Set/Coast or Resume/Accel Switch Shorted > E68 - Cruise Command Problem > E70 - Intermittent TPS Signal > E71 - Intermittent MAP Sensor Signal > E73 - Intermittent Coolant Temp. Sensor Signal > E74 - Intermittent MAT Sensor Signal > E75 - Intermittent VSS Sensor Signal > E80 - Fuel System Rich > E85 - Idle Throttle Angle Too High > E90 - VCC Brake Switch Signal Problem > E91 - PRNDL Switch Problem > E92 - Heated Windshield Request Problem > E96 - Torque Convertor Overstress > E97 - P/N to D/R at High Throttle Angle > E98 - High RPM P/N to D/R in ISC Range > E99 - Cruise Servo Apply Problem > > Body Control Module Codes > F10 - Outside Air Temperature Sensor Circuit > F11 - A/C High Side Temperature Sensor Circuit > F12 - A/C Low Side Temperature Sensor Circuit > F13 - In-Car Temperature Sensor Circuit > F14 - Diesel Coolant Sensor Circut > F15 - Solar Sensor Circuit Failure > F19 - Blower Motor Failure > F30 - Display Panels to BCM Data Problem > F31 - Display Panels to BCM Data Problem > F32 - BCM-ECM Data Problem > F40 - Air Mix Door Problem > F41 - Cooling Fans Problem > F46 - Low Refrigerant Charge > F47 - Low Refrigerant Charge > F48 - Refrigerant System Problem > F49 - High Temperature Clutch Disengage > F50 - Coolant Temp. too High > F51 - BCM PROM Error Indicator Automotive Network, Inc., Copyright ©2012
