2004 Intrepid Stall and Check Engine Light
ajsdurango
01-12-2005, 11:41 AM
I own a 2004 Dodge Intrepid SXT with the 3.5 High Output engine with 37,500 miles. A couple weeks ago, the check engine light came on and stayed on for about 20 minutes then turned off. Late last week while sitting at a stop light, the car stalled. It started right back up and ran fine through today. This morning, after about 5 minutes of driving, the check engine light came on and after another 10 minutes of interstate driving, the car stalled at 55 mph, caught itsself and continued running normal after that.
Any suggestions on what this could be, please help. Warranty ran out 1500 miles ago.
ajsdurango
01-12-2005, 04:11 PM
Was able to pull up the code of P0344 Camshaft Position Sensor Circut Intermmitent.
A. Souphound
01-13-2005, 05:08 PM
It sounds like maybe a loose connector at the Camshaft Position Sensor. I suggest you wiggle the wiring to the sensor while the engine is idling to see if it will stall. Disconnect the CPS connector. Check the (-) (black/lightblue wire) with a VOM for a good ground. With the ignition switch to 'On' position (engine not running) Check the Reference voltage between the Orange wire (+) terminal and the (-) Black/Lt Blue terminal. Voltage should read 8V. If reference voltage is present, check for cranking signal. Install the electrical connector to the CPS. Backprobe the tan/yellow wire (+) and the Black/Lt.Blue (-) wire and monitor voltage while turning the engine over very slowly by tapping the Ignition switch without starting the engine. Monitor the voltage. Voltage should fluctuate from 0.3V to 5V
Alvin
hajajm
01-14-2005, 06:10 PM
the same thing happend to me too , its the camshaft position sensor plug , it gets little loose sometimes , after i wiggle it , the car turns on , and i had the same code too @ autozone , i fixed the plug and the check engine light went off
