New plugs, now car shudders
racerblade
01-12-2005, 08:58 AM
Last night I installed new OEM spark plugs in a 1990 Regal 3.8L (165K miles). The engine now turns over faster.
Now I noticed that the car shudders between 45 and 55 MPH. Anything below or above that and everything seems fine.
Any ideas?? Could it be the oxygen sensors?
BIG-L
01-12-2005, 12:25 PM
Sounds like you have a problem with the plug wires.That happens alot after a plug change on older wires.
~Larry~
tman
01-12-2005, 03:43 PM
Usually make it a habit to replace plugs and wires at the same time.
Also, check to make sure you've gapped the plugs to 35 thousandths(.035) before installing them.
dwalmop
01-12-2005, 04:33 PM
Another common problem when replacing spark plugs, especially if they're hard to reach, is accidentally cracking them while installing.
racerblade
01-13-2005, 10:41 AM
Thanks for the reply.
I thought the gap specified is 0.06. Is that not correct?
Thanks,
Rick
BIG-L
01-13-2005, 12:14 PM
Correct....0.060
tman
01-13-2005, 04:32 PM
Right you are rick, I was thinking of a different engine.
