Help with Type R Swap please!!Changez2005 01-12-2005, 04:03 AM Hi there, I'm new the the forums eventhough I've read here all the time. I signed up here to ask for help. I have a 1998 Integra Coupe automatic. Eventhough it gets me around, I want a Type R for quite some time now. I want to first start off with the engine. I'm a beginner when it comes to mechanical works and what is needed to make a swap. But I made up my mind about the swap and I bought a JDM B18C Motor. Here is the site: JDM TYPE R MOTOR (http://www.jdmsource.ca/honda/b18cr.html) It says that it comes with the: -JDM B18C Engine, -Manual Transmission, -JDM ECU, -Alternator, -Air Conditioning, -Power Steering, -Pump, Distributor, -Wiring Harness I just want a car that can push out around 200-250HP with ALL MOTOR and NO Turbo. I'm asking are those all the parts that I need to make the swap? If there's any other parts or anything else I need to do, please PM or EMAIL me and I will be greateful. Thank you. BrokenLimits 01-12-2005, 07:55 AM Going to need these if going from auto to man Slave Cylinder Hydraulic Lines Clutch Master Cylinder Hydraulic Reservoir Clutch Pedal Clutch Pedal Sensors AND plugs Brake and Gas Pedal Shift Linkage Shift Boot Shift Knob Upper Transmission Mount Front Transmission Stabilizer crxlvr 01-12-2005, 12:21 PM well the type r makes 200hp out the box, if you want more id suggest high compression pistons, since you are going all motor, upgraded rods, new valvetrain, maybe a P&P on the head and a 3 angle valve job. Automotive Network, Inc., Copyright ©2012
