block cleaningfordperson 01-11-2005, 02:45 AM I have a block that had oil+coolant mixed together and now it has this yellowish stuff on the walls. I tried running water thru it but it would get it out... any ideas how I(or a shop) could clean it out? Tom Classicrocjunkie 01-11-2005, 01:51 PM Simple green works like the shit... cover entire are and let sit for 10 min.. spray off. bigdaveangell 01-12-2005, 12:58 AM most degreasers or a penetration oil will work fordperson 01-12-2005, 11:27 PM what about rust? any liquids that would clean rust without having to go with a brush as most of the surfaces there arnt reachable. Tom big dude1 01-13-2005, 09:31 PM lol use a pressure washer!!! :) bigdaveangell 01-13-2005, 09:34 PM lol use a pressure washer!!! :) You could even take the block to the car wash noshun 01-23-2005, 11:11 PM You could even take the block to the car wash CLR TypeGsR 02-08-2005, 07:27 PM woohoo blown head gasket take out the oil plug holes on the back of the blocki and stick a hose in them and it should have clear water running throughout the block if it is clean clean the oil passage ways. dosent blown head gaskets suck noshun 02-08-2005, 11:47 PM woohoo blown head gasket take out the oil plug holes on the back of the blocki and stick a hose in them and it should have clear water running throughout the block if it is clean clean the oil passage ways. dosent blown head gaskets suck Anything that prevents full power does! Even A/C and p/s but compromises are always made otherwise it wouldn't be street legal! Automotive Network, Inc., Copyright ©2012
