low tire pressurecbfc1 01-10-2005, 10:06 PM the low pressure tire light wont go off in my car. i can reset the oil one but but the tire wont reset. Also I have a brake light on inbetween tachometer and speedometer help, blk_silverado 01-11-2005, 08:11 AM Check to see if all of you tires have about the same psi in them. If they don't, go air them up. If they do, then just start the reset procedure. Take the fuse panel cover off. Turn the key to the ON position. Hold the RESET button for 3-5 seconds or until you hear the chime. Release and then, if I remember this correctly, you have to press the RESET button again. You will then see the low tire pressure light blink and go off. JTrujillo86 01-11-2005, 08:33 AM The BRAKE light on between the tach and the speedometer means that you are low on brake fluid. Check the resivior. If that is okay on fluid, take your car in. You're not supposed to drive with that light on. Jeremy Automotive Network, Inc., Copyright ©2012
