1998 ford contour/transmission
Glenn1962
01-10-2005, 09:40 PM
I have a contour that the transmission only works after the car has been
shut off for a minute or two. Then you start it and it seems like it won't
move at all then it goes into gear. It will go for 100 feet or more then it's
done. It acts like it's in neutral. Shut it off and wait 1 or 2 minute's then it might go again. If not shut it off again and it will go again. This won't work in reverse. Only in drive. Reverse don't work at all. I can go around the block, but it takes me about three or four times of shutting it off and starting it up again. when it does work it takes off like it's just fine. Then no tranny again. ??????? TCC Solenoid??? Clogged filter??? Clogged screen???
Thanks,
Glenn
Slade901
01-10-2005, 09:58 PM
Glenn,
What happen to your previous posts? It looks like it was deleted.
Anyway, when you say it will go for 100 feet or more then it's done, does it mean that the transmission loses power and the vehicle just slows down but the engine is still running fine or the engine dies too?
Does the engine have a good IDLE if you just let the engine run at IDLE?
Glenn1962
01-10-2005, 10:00 PM
engine is running fine. just the tranny acts like it's in neutral.
beyondloadedSE
01-10-2005, 11:41 PM
atx or mtx?
ceccal
03-03-2005, 04:22 PM
Thanks,
Glenn
Glenn
I have the very same problem PLEASE let me know if you find out Anything
Thanks
ceccal@yahoo.com
lozanet
03-08-2005, 07:51 PM
Well, i had the exact same problem, the transmission was totally broken so had it fixed, it cost me 800 dlls.
ceccal
03-08-2005, 08:35 PM
is that buying a used or rebuilt or having that one reparied
lozanet
03-09-2005, 11:13 AM
having that one repaired
