Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Sentra/200SX (USDM FWD)
Old 01-10-2005, 11:43 AM   #1
tipota
tipota Normal reputation
drifting with a sentra
my friend told me you could only drift with manual cars, and ive been thinking of how i could drift my with automatic 94 sentra. i never wanted to pull the e-brake while driving because i heard if you do its bad for the engine and the front axle. yesterday however, i figured out that i can drift if i throw the car in manual, start a turn, and pull the e-brake. ive only done it once, and before i do it anymore im wondering if its bad for the car at all. i figure that when the cars in neutral, its just like pressing the cluth and the engine is disengaged from the wheels so its not affected by the e-brake. is this true? and also, does pulling the e-brake while the car is driving have a negative effect on the axle?
tipota is offline   Reply With Quote
Old 01-13-2005, 11:12 AM   #2
muphasta
muphasta
Send a message via AIM to muphasta
That isn't really drifting. That is sliding. I don't know if that will cause any problems, but it probably isn't a great thing to do daily.
muphasta is offline   Reply With Quote
Old 01-13-2005, 11:58 AM   #3
tipota
well i wont do it daily, my main concern is that nothing bad is happening to the axle. how does the e-brake work? does it wrap around the axle or something? and also, what then is drifting? i thought it was a controlled slide, meaning that as long as you slide around a turn without spinning out.
Old 01-13-2005, 12:10 PM   #4
mi69camaro
mi69camaro's Avatar
mi69camaro Normal reputation
Send a message via AIM to mi69camaro Send a message via Yahoo to mi69camaro
Re: drifting with a sentra
Yeah that's what i thought it was...but not like i know anything!?!?
"Go Ahead Street Race..You Only Live Once" j/k
-----Racecar is Racecar Spelled Backwards-----
Proud Owner Of-->
1961 Ford Falcon--> Four Door
Straight 6- 170ci.
3 on the Tree
101rwhp ~lol~
289 or 302?? 4-speed
Jon D. Rock On!
God Bless
mi69camaro is offline   Reply With Quote
Old 01-13-2005, 12:19 PM   #5
muphasta
muphasta
true drifting can only be done w/rear wheel drive cars. I am not sure of the exact process on how to do it, but they break the back end loose, and the rear wheels "drift" out and continue to spin while the car goes through the turn sideways.
ever seen those midget race cars w/the big wings on the roof? They race on dirt tracks generally, and those guys drift through the turns.
Basically, if you don't have rear wheel drive, you cannot drift.
Old 01-13-2005, 12:36 PM   #6
tipota
so what am i do? controlled sliding?
Old 01-13-2005, 02:21 PM   #7
muphasta
muphasta
I can't really say how "controlled" your sliding is. But that is probably more accurate than drifting.
Old 01-14-2005, 04:23 PM   #8
qr25sentra
qr25sentra Normal reputation
yea its considered sliding.. just find a nice slipper road (slightly wet) and let go of the gas,pull the e brake and turn the steering wheel.
2003 nissan sentra 2.5 limited edition. I/H/E/TBB- death by hurricane wilma..
Dec.1,2005- Altima SE-R(silver, 6spd) stock for now..
qr25sentra is offline   Reply With Quote
Old 01-16-2005, 01:39 AM   #9
97sentra
97sentra Normal reputation
it fun to slide with a front wheel drive. your axle will get mess-up not becuz of the e-brake but becuz of the way the axle are bent when you turn. but if you have money to buy axle, have fun sliding.
97sentra is offline   Reply With Quote
Old 01-20-2005, 04:33 AM   #10
Liquid_Neon
Liquid_Neon Normal reputation
Send a message via AIM to Liquid_Neon
ebrakes dont touch ur front end... they are directly attacted to your rear brake drums/discs via a cable.
when u pull it up, it pulls the brakes closed.
the axles only wear out because they are not designed to handle so much force and weight the way a slide does.
doesnt bother the motor, it isnt attached to the rear wheels at all.
also, another way to balance the car and slide around corners is with careful control of the brakes and gas at the same time. it allows for less understeer(going straight) and sometimes oversteer(rear end sliding out) if u need it. I do it in my pulsar NX, and with practice you can drive quite fast through the twisties.
Liquid_Neon is offline   Reply With Quote
Old 02-04-2005, 10:22 AM   #11
bbissell05
bbissell05 Normal reputation
why anyone would even attempt to "drit\ft" an automatic sentra is beyond me, but if you really want to do it here's the proper way...
leave the car in gear and accelerate while pulling the e-brakeand turning...this works best when you're already moving, and with enough power you can actually drag the rear wheels around behind you kind of like a "drift"
bbissell05 is offline   Reply With Quote
Old 02-04-2005, 12:26 PM   #12
tipota
i onyl drift with it because its the only car i have. ive been looking for a 240sx lately though. i stopped doing it because i found out its bad for the axle, and id rather spend 1000 towards a 240sx than a new axle for my sentra
Old 02-06-2005, 12:04 AM   #13
klohiq
klohiq's Avatar
klohiq 0
if you do get a 240sx...make sure you have a little extra saved up for crashes...think about getting an s13 since they are 10x cheaper to fix (much greater parts availability).
lastly...some people in japan have installed skyline rear axles because their stockers keep breaking...but I think that's more due to the excessive hp they produce than the lateral forces.
klohiq is offline   Reply With Quote
Old 02-09-2005, 01:26 PM   #14
Fialchar
Fialchar Normal reputation
Send a message via AIM to Fialchar Send a message via MSN to Fialchar Send a message via Yahoo to Fialchar
True drifting is with RWD cars, automatic/standard wont make much difference. As you go around a curve, you would pull the e-brake and spin the wheel, then release the e-brake and tap the gas/foot brake to control the drift. Honestly, if you haven't drifted much before, get some training first. Lots of smaller annoyances can happen, such as: If you don't know how to counter steer or forget to, the road will grip your tire and peel it off of the rim. That's not fun when you're going 50+ mph..
Again, I'd HIGHLY recommen d you go to a racing/drifting school before you attempt to drift. Even experienced drifters make mistakes, and throwing a car around at those speeds with no grip can be fatal. Or worse, it could total your car.. (R.I.P. 1ZZFE and R.I.P. 2000 Saab 9-3 Turbo T.T)
Fialchar is offline   Reply With Quote
Bookmarks
Google
Web AF
