DET swap/tranny issuesG20ps 03-09-2002, 03:11 PM I am starting to swap a Bluebird DET into my '94 G20, and had a question about the transmission. I got a LSD tranny out of a '96 Primera to go with the engine, but as I look at my tranny and the new tranny, there is no place on the Primera tranny to put the crank-angle sensor, as it is mounted in holes on the front of my G20 tranny. I was wondering if anyone had encountered this before, and what they did to correct it? Should I tap and drill new holes in the Primera tranny for the sensor (could I possibly mess up the timing doing this?) Should I swap over the front housing from the G20 tranny? (I'd have to totally disassemble the tranny to do that). Should I see if it's possible to have JWT reprogram my ECU to not use that sensor? (I'm using the USDM G20 ECU, and having it tuned for a Bluebird. Also using the USDM G20 wire harness.) Sorry for the long post, but any help, as quickly as possible, would be greatly appreciated. G20ps 03-10-2002, 03:35 AM nevermind, I figured it out. I'm really not as dumb as I sound. T4 Primera 03-10-2002, 03:54 AM So what did you decide to do??:confused: P10DET 03-10-2002, 12:41 PM Originally posted by T4 Primera So what did you decide to do??:confused: Ditto. If you swapped gearbox cases, you have some shimming to do. G20ps 03-10-2002, 08:32 PM That sensor is a crank-angle sensor mounted on the front of the tranny. It takes readings and *can* make adjustments to timing, fuel, etc. But when I get my ECU reprogrammed by JWT for the Bluebird, I can tell them to just bypass that sensor, and then I can just leave it off. Automotive Network, Inc., Copyright ©2012
