Programming Keyless Remote LS400chadmaisel 03-09-2002, 11:23 AM Does anyone know how to program a keyless remote for a 95 ls400. I lost my remote and bought a new one. The dealer wants $65 to do it, but I'm sure it's pretty easy. Thanks nahmed 06-03-2002, 03:08 PM did the new keys come with a manual, especially with the new chip? Kavanos 09-21-2002, 08:12 PM I have some instructions on how to program a new remote for a 96 LS400. I've tried it, but it doesn't seem to work. But, it could be the remote I have is no good??? I'll give you the instructions so you can try. If it works for you, please let me know. Set-up: Key out of ignition and driver's door open & unlocked & passenger's door closed and locked. Procedure: 1. Insert key in ignition and remove. 2. Press the driver's MANUAL door lock switch, LOCK to UNLOCK, 5 times. 3. Close and open the driver's door. 4. Press the driver's MANUAL door lock switch, LOCK to UNLOCK, 5 times. 5. Insert key in ignition and turn ignition ON and OFF... Once to add a new code. Twice to rewrite over ALL previously stored codes. Three times to confrim how many codes are stored in the ECU. 6. Remove teh key from ignition. The car will now respond back the selected mode by automatically locking and unlocking the doors... once to add a new code. twice to rewrite over all previously stored codes. one to four times (slowly) to show how many codes have been stored. If the confirm mode was selected the process is complete. Otherewise: 7. Press the transmitter switch on the key for 1 second. After the signal is received, the car will respond by automatically locking and unlocking the doors once. GOOD LUCK!!!! btran 09-25-2002, 03:20 PM Kavanos after #7 add 2 more : 8) Close & Open driver door 9) Press transmitter switch on the remote for more than 1 second I just bought a remote and programming procedure (same procedure as you described in your messade) plus item number 8 & 9 above. It WORKED !!! Make sure your keyless remote FCC code # is the same in your Lexus manual good luck Kavanos 10-02-2002, 11:29 PM Thanks btran. I've figured out now that the FCC# does not match. That's why the instuctions won't work for me. Automotive Network, Inc., Copyright ©2012
