back seat removalny neon 01-08-2005, 03:45 PM im having trouble removing the back seat. i have a 95 neon. can someone help me please? KoZoTo 01-09-2005, 04:59 AM First, take the rear seat cushion out of the car.* To do this you get you fingers under the front of the cushion and pull it up.* There are two clips, one on each slide, that hold it in.* Take it out and set it aside. Now you should see two large torx bolts holding the seat belts and the rear seat in.* CAUTION:* The paint on the insulation below the rear cushion will stick to anything, especially shoes. Remove the #55 Torx bolts holding the seatbelts.* Be sure to remember which seatbelt goes where.* The rear seat can then be lifted up and removed from the car. ny neon 01-10-2005, 03:01 AM thanks Automotive Network, Inc., Copyright ©2012
