ok Im Installing a code alarm ca510. I need to know if the tach wire needs to be hooked up to make this thing operate. Ive tried to program this unit to tachless mode be it keeps defualting to tach mode. When i run diagnostics on it, it flashes 7 times saying it hasnt learned tach signal. If that wire does need hooked up where do i connect it. directions say neg wire up by coil but that is nearly impossible. please help
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
