Opinion on Caprice with propane as fuel...
at1212b
01-08-2005, 11:02 AM
What do you guys think of a 88 caprice 8 cylinder, that uses propane as the fuel for $700? Thinking of purchasing one. Is this because it was used as a cab previously? Any pros or cons regarding this and possibly why this car is cheap?
http://www.canadatrader.com/result/detailinfo.aspx?adID=3241710 is the link for the ad.
Thanks!
TommySS
01-08-2005, 02:49 PM
Propane is cleaner, octane is higher (don't remember the number, but it's over 100).
It's not cheap, and unless you have a pretty big tank, you'll be gasing up a lot.
Just my .02
at1212b
01-08-2005, 08:51 PM
I guess that's why its cheaper because of the increased gas costs. Though I was reading because of the cleaner fuel, the engine can last longer.
Any ideas on the cost of converting it back to a gasoline engine?
TommySS
01-12-2005, 07:46 PM
Wow - this is straight propane? That's cool !
All you need to do is obtain a gas tank, fuel pump, and carburetor, and plumb new lines.
Since the range is not great, a lot of propane cars already come with gasoline provision.
at1212b
01-13-2005, 07:59 PM
Any ideas of the advantages/disadvantages for this type of car/engine?
Don't plan to do much driving. Just on the weekends.
TommySS
01-13-2005, 08:03 PM
Range and fuel availability are limited, but that's about all.
Michel73
01-18-2005, 12:00 PM
My caprice drives on propane also, no problems at all. I don't know about canada but in europe propane is about 4 times cheaper then regular gas. If you would like pictures of my propane tank just look at my gallery. Check my ride at: http://www.cardomain.com/memberpage/643759
Good luck with the caprice!!!
Michel
