Re: running out of gas...now won't start
Try removing the filter and intake hose and spray directly into the (open) throttle body, then try to start. The air filter may be trapping too much spray, plus you can screw up the MAF sensor with too much.
As far as replacing the pump, you'll need to drop the tank, get some snap-rings off, and swap the $300 pump out for a new one. But when you turn the key to ON do you hear a hum that lasts maybe 2 seconds and then stops? If not, then your pump is out. If so, you might have a different problem.
