How do i disassemble a 2002 honda civic dash boardBobbyl12342 01-06-2005, 08:05 AM Can someone please tell me how to disassemble a 2002 honda civic dash board im trying to install a cd player could someone please help. you can e-mail me the info at bobbyl12342@hotmail.com thank you riccimangan 01-15-2005, 08:29 PM you didn't say what kind of civic it was, if its one of them 2door thingys i cant help coz we dont have them over here, if its a 3dr hatchie then your in luck, Open the dash and squeeze the 2 top corners together to drop it right down on its hinge, now remove the panel covering the fuse box, from here you can reach the screw on each side of the centre console. loosen the screw a little, no need to remove it.remove the shift knob and get your fingers behind the panel, pull this off, theres only clips holding it just dont tear it right out, disconnect any wiring conected to the panel. the rest should be easy. the upper panel with the stereo in it clips off the same way. just remember to take it easy on the panels, if you pull them to hard you'll leave stretch marks. once you have it all out you'll be able to figure it out pretty easily. then just stick it all back together in the reverse of removal. even if its not a hatchback some of the parts may be the same or similar,. hope that helps you out,.,.,.,.,.,. Automotive Network, Inc., Copyright ©2012
