What are the views and opinions on this swap.. Also, could someone give me the low down on what exactly it's going to entail.. I know it'll bolt right up.. I need a wiring harness and a new ECU but which ECU should I go with.. Help me out here..
best bet would be to but the gsr motor swap, sell everything from the swap except the motor, then bolt your tranny up to it, use your gs distributor, youll have to wire up the vtec pressure switch , knock sensore extra o2 and vtec solenoid then go with a pr3 or pwo ecu
