Problem with heat and it's the coldest of the year..Sid Daley 01-05-2005, 03:54 PM 1992 Suzuki Swift, about a year back the fan stopped working at all but the max speed. I was fine with that because I had heat, the other day it stopped working entirely. I checked the fuses and their was a 15amp blown, so I changed that and it worked again. Now it has stopped working totally and the fuse is good??? There is still heat when the car is moving but no fan. Thanks Sid geozukigti 01-23-2005, 12:06 AM quite possibly a bad resistor pack. Pick one up from the junkyard. The resistor pack is in the blower motor housing. mrrob 01-23-2005, 12:47 AM Call your local parts store or dealer, they are not that expensive! Good Luck Mr.Rob Sid Daley 02-09-2005, 10:29 PM Thanks Guys, I'll check that out. I'm tired of scraping ice off the inside off the glass. LOL. Probably not the electric motor then? Sid Automotive Network, Inc., Copyright ©2012
