Rear wheel lock up 1999 Ranger?
mikebike
01-04-2005, 10:42 AM
The rear wheel of my 2x4 1999 Ranger is frozen. The wheel locked a little recently while braking. Now, it is frozen locked after applying the emergency brake. Is this a brake problem or rear diff problem?
Mike
mikebike
01-04-2005, 10:43 AM
I should mention, I can drive in reverse and the wheel rear wheel rolls. Going forward it is locked.
BuickGS
01-04-2005, 08:06 PM
Sounds like a brake problem to me. Do you knoe for a fact that your ebrake disengages?
|4x4|_Neurotick
01-06-2005, 09:09 PM
I had almost the same problem with my ranger. I fixed it by jacking the truck up rolling the tire back and forth then went to the other side and did the same thing i havent had the problem since.
mikebike
01-07-2005, 09:20 AM
I am lucky. It was not the rear diff. The emergency cable was stuck in the on position. $220 replaced both cables and all is fine again.
Mike
