IAC overall lengthastralepic 01-03-2005, 09:18 PM Hey everyone, here's what I've got going. I've got a 93 GMC Sierra 350, TBI. I've read I think every post on the internet as to what my issue may be and here's where we are. This started as a very sparodic rough idle, but proceeded to get worse. I pulled the Idle Air Control using the information in my Haynes manual. The first thing I noticed is that it was so loose that I could literally turn it with my fingers. I decided to go ahead and pull it out to check it by moving it side to side. By bad luck chance, I moved it in. Looking back into my manual, this isn't bad except that I do not know the overall length for the IAC itself. Can anyone tell me what it is? 93 GMC Sierra, 350 TBI, 2WD, 230,000 never any major mechanical work needed. I really need help on this one or I fear this may be the end. Thanks! sechracer 01-04-2005, 08:20 AM Not sure what the actual length is, but autozone sells one for it for about $28 new, all you need is the oem # off of it to crosss reference. For the price, I would check out a new one, not to mention you can take the measurement off the new one right there in the store. astralepic 01-04-2005, 01:31 PM Straight out of the box huh? I assumed their was some type of variance considering the manual said to measure the old one and compare to the new one. I'll give it a try and let you know. Thanks! GMMerlin 01-04-2005, 02:40 PM You don't want to install the new one if it is turned all the way out...this could damage it. Using your hand, just push the pintle in a bit then install the valve..turn the key on, then off 2 times then start the vehicle. astralepic 01-04-2005, 08:36 PM So I purchased a new IAC and still have the same issue. Out of the box, the pintle was quite a bit shorter, but I tried it anyways. I don't know that the idle was worse, but it definately was not better. Decided to take existing and compare to new one. Moved pintle out and engine seemed to idle just a touch better. Don't think this was my issue, but for $28 I can atleast begin to look elsewhere. I went ahead and bought a new O2 sensor, but it'll be the weekend before I can get to it. I'll keep you guys posted as to the outcome. If you have any other suggestions, please let me know. I also plan to put new AC Delco plugs in too. Will check distributer and rotor button, but both appeared fine just days ago. dougo 01-06-2005, 02:59 PM you most likely you have carbon holding open the e.g.r. valve or the valve is stuck open . astralepic 01-06-2005, 04:21 PM I can move the diaphragm in the egr valve using my fingers. If I can move it, do you still think it may be stuck open? The valve is less than $50, so I'm tempted to just replace it. Automotive Network, Inc., Copyright ©2012
