97 RAV4 Timing Beltcardriver 01-02-2005, 12:06 PM I've got a bad slapping noise at idle, and acceleration. It sounds like my timing belt is slapping the cover. I just got a Timing Belt Kit (timing belt, tensioner pulley, idler pulley). I would love to save the money and do it myself, but I am a noobie when it comes to front wheel drive cars. I *almost* have the top part of the timing cover off.. All bolts (that I could find) are out, and the cover is pretty loose (I can see the belt). I just can't get it all the way off. I noticed what appears to me to be the passenger side motor mount right in the middle. Does the motor mount need to come off? If so, do I just brace the motor under the oil pan, or another part? Will the motor have to come out of the vehicle do change the items that came in the kit?? I have pretty good selection of tools at home, and access to others if needed, so I feel that I could handle doing this with a few pointers, as long as the motor doesn't need to come out. Thanks for any help that comes my way! patsgmc 01-28-2006, 01:23 AM Wow, a month and no replies? Bummer. I figure that you have it all sorted out by now.. How did it go? I've done a timing belt on that engine in a Rav4, Took twice as long as I figured, That motor mount, and everything else on that side of the bay had to come out. I didn't yank the engine, but I did grab the lift tackle with my picker, to hold the engine after removing that mount. I think it's ok to jack via the oil pan, use a wood block, and go easy. Pat Automotive Network, Inc., Copyright ©2012
