1992 explorer with4.0
heartj
01-01-2005, 08:24 PM
i have a explorer 4.0 at a pull it has the a timing rattle like it is not advancing i replaced plugs,wires, coil pack and the crank position sencer what next
RexNfx400
01-05-2005, 12:16 AM
I think you would mean "like its not retarding" How about a knock sensor?
Carl Shannon
10-11-2005, 05:21 PM
Did you ever solve this problem. I would be interested in the solution. Thanks!
asemstr
10-11-2005, 11:03 PM
4.0 OHVs are known for carbon issues that can lead to; spark ping (from increase in comp ratio), ticking (from piston contact with deposits in quenche zones), buzzing and rattleing (from carbon loose in the exhaust sys) First I'de recommend getting a good combustion chamber decarb additive from the local autoparts store, and run with that for starters. Can't promise this coarse of action will cure it, but the next option is a bit riskier! In alot of exsteme cases the deposits are so tough that it can take flooding the chambers with special solvents or blasting them with ingested shots of water, :nono: but if this isn't done carefully you can hydro-lock the engine! :2cents: You may want to have a shop that offers induction and de-carb services perform that chore if my first sugestion doesn't help.
