At what stage would Water Injection be appropriate??P11GT 03-07-2002, 06:35 AM As many people are either researching / undergoing turbo conversions, i thought that this question may come in handy. I know the basics of a Water Injection system, what it does, but When would this system be appropriate?? At what power level?? Apart from 'Aquamist', who else makes similar systems?? links please:D G-Forces 03-07-2002, 08:07 AM You need it when you want more boost but you don't want to open up your motor and get lower compression internals. Or if you're running on the ragged edge and you want a little piece of mind. P11GT 03-07-2002, 10:30 AM oh right, so cos ive done my pistons, i'll be ok upto 300HP??? G-Forces 03-07-2002, 10:43 AM With proper tuning I don't see why not. Dcshoecousa 03-07-2002, 11:04 AM http://www.automotiveforums.com/vbulletin/t25007.html Old post for some info. I've installed many NOS systems, mostly on Jettas and Hondas/DSMs but people had no turbo/internal upgrades, they wanted cheap boost. Personally, I don't recommend it at all. But this are mostly all talk people who say "Yeah .. well, I want NoS for now, and I'll upgrade my internals later ..." Sure, why not take that 1200$ <CA> and save it towards a turbo system or internal upgrades. Anyways, it's their car. At least change the rods, valves. (especially the exhaust valves, weak) Both the rings and pistons are very sensitive to detonation. If you hear a tock tock noise when the throttle is applied, this is the symptom. I've seen this too many times in my life, and I'm only 20. If the valves, pistons, rings and rods are upgraded, the engine becomes much stronger. In fact, the bottom end itself is stronger than that of the turbo. This is how I work it ;) Once you have your turbo properly tuned, ECU programmed. Wait a while before doing more mods, and see how the engine runs. Then check the engine for leaks, etc... Then gradually, I'd upgrade the stock internals, get a new performance clutch, very important. ONLY then would I add 50 shot nos to start with and test it on the 1/4 mile. But if you use NoS casually, and you have upgraded internals, it's all good, safe, and wise. Your car will be perfect. Just my .o2 cents. b-b00gie 03-07-2002, 11:15 AM Originally posted by P11GT ... When would this system be appropriate?? At what power level?? From what I've seen of turboed SR20DE's or DET's I'd say: -Up to 275whp dont worry about it -275whp to 300whp, I'd concider it -300whp to 350whp, I'd get it just to be on the safe side -350whp+ get it. Like I've said before, people have run turbo'd DE's over 400whp with *stock* internals and water injection. Dcshoecousa 03-07-2002, 12:07 PM 275whp to 300whp Logic, to get this boost, you'll have changed internals. Same difference. It's common logic, you don't want detonation, thus, if you have a turbo, you NEVER add nos until your car is pretty much bullet proof, all upgraded internals. If not, then you're just killing your pistons, and your valves will get damaged, or melt. And the question is not at what power gains, the question is HOW much `shot' of NOS for the engine mods you have, and also how much PSI you are running. More compression mixed with NoS = EXCESSIVE HEAT Or you can run an advanced system to kill turbo lag, your nos kicks in from applied throttle to 2000 RPMS, then the turbo kicks in after lag. Many people have this advanded setup. Nos is at your own risk, it's never 100% safe, so make sure your internals can handle the heat. And there is also the question, just because you can, doesn't mean you should. Always a risk, be smart, be wise. Very simple. G-Forces 03-07-2002, 12:14 PM Originally posted by Dcshoecousa But if you use NoS casually, and you have upgraded internals, it's all good, safe, and wise. What does NOS have to do with water injection? I think you misunderstood his question. :D G-Forces 03-07-2002, 12:17 PM Originally posted by Dcshoecousa 275whp to 300whp Logic, to get this boost, you'll have changed internals. I agree. But with stock internals and 'water injection' you can get 300whp pretty easily. It's been done lots of times on the SR20DE. The first time someone did this was WAY back in 1998. Read this: http://www.se-r.net/about/200sx/scc/feb99/index.html G-Forces 03-07-2002, 12:20 PM Originally posted by b-b00gie -300whp to 350whp, I'd get it just to be on the safe side -350whp+ get it. :hehe: I know people have done it, but personally anything over 300whp and I'm pulling the motor and putting in some low comp internals. :D Something about running out of water at the wrong time just scares me. :eek: I know it doesn't use a lot but still. Dcshoecousa 03-07-2002, 12:24 PM haha, I read wet system/nos. Does it show I went out last night, did not sleep much, spring break and I am at work, oh hehehehe. my bad! :o *Yawn* G-Forces 03-07-2002, 12:26 PM Maaaan, take a couple advil and go have a nap! :D v_knot 03-07-2002, 12:46 PM NOS are for civic monkeys who holds a banana thinking it is a wrench! G owners with NOS are also monkeys. P11GT 03-07-2002, 05:05 PM Hey guys, BIG thanks for the info, very helpful. I'll have to read it through again so it sinks in. G20TurboVisionCrew 03-07-2002, 05:49 PM Once again 100,000 questions :( When i get my turbo kit, with all the mods b-boogie gave me, I could just slap on the water injectors temporarily,(until i get more cash flow for the internals) push that 300hp to my stock internals and i would be fine? Not really clear on water injection, how much does that set up usually cost? what is the durability? stability? what is the usual time period water injectors last? What is the whole process of the injector, how do they work??? :D v_knot 03-08-2002, 07:55 AM You're too concerned of maintainability, durability, reliability and the whole shebang, to begin a turbo conversion project. You got to be able to take some risks. BTW, the above criteria are all depending on the craftsmanship. G-Forces 03-08-2002, 08:12 AM Originally posted by G20TurboVisionCrew Once again 100,000 questions :( Personally I've been reading up on turbo systems and such since I bought my car almost 3 years ago. It's tough to just barf out all that into on command. I suggest you start trying to find everything you can get your hands on about turbos. Have you gone over to SE-R.net and read everything on that site about turbo cars? Have you arsed around in the se-r-list.org/archives for hours on end? There is a wealth of information out there. Put your turbo project on hold for a bit and do some of your own research and parts/price hunting. I get the impression that we keep spoon feeding you info. I'm not attacking you I just think you need to learn some of this for yourself. There is no 'road map' for turboing your car. There are a lot of personal desires and compromises that need to be made. I suggest you spend some good quality time with se-r.net and se-r-list.org/archives this weekend. Data from guys like Kojima, Cadel, and Hassinger all know thier shit about turbos. P11GT 03-08-2002, 10:31 AM G- im feelin' ya must do the same. G20TurboVisionCrew 03-08-2002, 01:13 PM I've actually been going to through the archieves but i have not found real threads with a whole bunch of info, or info i am looking for, maybe i am looking in the wrong place, i mean i have found a few, but, ah, never mind i just gotta spend more time looking through them i guess, i only have about 3 hours worth of reading threads, i guess i still need to add hundreds to that..... Besides, i like being spoon fed, hehe j/p.... I feel you G, still got alot more research, i was planning to start my project on april 17... I think thats enough time to explore, but if not, i will hold off for a longer time... I wanted to get my turbo by may 25 for HIN but hey, there is always HIN's. My turbo is more important... v_knot 03-09-2002, 01:56 PM You're giving yourself a whole month to do research on the project that could potential put your engine into a grinade? Even if you're an Einstein, things won't come out the way you hope for. I am giving myself at least 2 years for all the research. Look at G-Forces, he gave himself almost 3 years. Learning never stops, the assurance to do things right the first time is the objective of the turbo conversion. Automotive Network, Inc., Copyright ©2012
